PLEASE help- recurring problem
nickv
Hi All
I've had my adsl 1024 line for about 2 months now.And what a frustrating 2 months it's been. I've phoned telkom many times now, I've had them log a fault for me which they have assured me has been fixed but still the woes continue.Basically whats been happening is that my line will lose sync every now then.Telephony always stays working but I constantly lose ADSL sync.What makes it more frustrating is that some days it will stay rock solid in sync for 24 hours and other days it becomes totally unusable.I don't know what else to do.Any suggestions would be greatly appreciated.
My router info: BILLION ADSL single port router model 5200
ADSL Firmware Ver : FwVer:3.5.10.1_A_TC3085 HwVer:T14.F7_1.0
Line State : Showtime
Modulation : G.DMT
Annex Mode : ANNEX_A
--------------Downstream Upstream
SNR Margin : 10.0 14.0 db
Line Attenuation : 49.5 27.5 db
Data Rate : 2816 384 kbps
ROUTER LOG:
10/28/2006 8:45:7> netMakeChannDial: err=-3001 rn_p=80438138
10/28/2006 8:45:8> Last errorlog repeat 1 Times
10/28/2006 8:45:8> netMakeChannDial: err=-3001 rn_p=80438138
10/28/2006 8:45:21> Last errorlog repeat 11 Times
10/28/2006 8:45:22> netMakeChannDial: err=-3001 rn_p=80438138
10/28/2006 8:45:22> Last errorlog repeat 1 Times
10/28/2006 8:45:23> netMakeChannDial: err=-3001 rn_p=80438138
10/28/2006 8:45:23> Last errorlog repeat 1 Times
10/28/2006 8:45:24> netMakeChannDial: err=-3001 rn_p=80438138
10/28/2006 8:45:31> Last errorlog repeat 14 Times
10/28/2006 8:45:32> MPOA Link Up
10/28/2006 8:45:35> ppp_ready: ch:8047f9ec, iface:803ce7b0
10/28/2006 8:45:35> SNMP TRAP 3: link up
10/28/2006 8:45:35> Accept() fail
10/28/2006 8:46:31> SNMP TRAP 2: link down
10/28/2006 8:46:31> MPOA Link Down
10/28/2006 8:46:31> mpoaChannDown: ch<0> null iface
10/28/2006 8:46:34> netMakeChannDial: err=-3001 rn_p=80438138
10/28/2006 8:47:6> Last errorlog repeat 3 Times
10/28/2006 8:47:25> MPOA Link Up
10/28/2006 8:47:29> ppp_ready: ch:8047f9ec, iface:803ce7b0
10/28/2006 8:47:29> SNMP TRAP 3: link up
10/28/2006 8:47:29> Accept() fail
Running on AMD 64 4200 x2,asus A8R-MVP,MARVEL YUKON Ethernet (BUILT IN) network card
Thanx
Jah
Most likely bad line quality, had the same problem.
only way i could get telkom to fix it was to get a techie to my house, and show him my router stats (Had thousands of CRC errors).
Trick is not to let them close your fault until you are absolutely sure its fixed.
bekdik
You do have filters on any phone or modem plugged into the line?
