Hello, I just got a massive fright! I was just about to skype someone on our family HTPC and suddenly the cursor started moving. I moved the mouse and it moved again to chrome and opened a web page, I moved it again and it was forcefully moved back to opening a dropto webpage where it began to download an exe file that is 1mb. I fought with the cursor for a few seconds and they kept moving it back, at this point I ran and shut of the computer and disconnected my Router.
I am a above average knowledgeable techy. We have about 4 computers in the house, one HTPC with windows 10 that was hacked, 2macbooks a macpro, a few phones and ipads, kindle fires, etc and a synology nas as well as a number of IP security cameras.
I had previously been a bit lax as I wanted to access blue iris remotely so I had forwarded ports to my security cameras. Also, to control the HTPC I had tight vnc installed and unified remote so I could remotely control the pc from anywhere in the house.
before turning the internet back on, I changed my router password, removed all port forwarding in the router, through my cell connection changed my email and online password manager passwords and setup 2 factor authentication for both. I also removed my dynamic dns settings in my router in case they found me through that and twice reset to switch IP's. I also confirmed that my email had not been accessed by anyone outside my home.
I am currently wiping and reinstalling the HTPC completely from scratch and am running antivirus on each of my macs at the moment. I have disabled screen sharing on all my macs and will remove remote desktop management in my new windows install. I will also bypass the convenience of vnc and not be using it again and will forego remote access to my security cameras.
I have the 1mb exe file he downloaded and before I wiped the machine I scanned it with three different antivirus softwares and none of them picked anything up on it.
Obviously this leaves me a bit freaked out and would really appreciate any other advice on how to lock down my home computers and make sure this never happens again. Half an hour later my xbox one turned on by itself, first time that has ever happened, so I unplugged it from the wall. I know I can wake it through a windows xbox app connection, but nothing was messed with. Has me pretty on edge as they could have had access to everything on my computers and I don't know if this is the first time they have accessed it.
Any security guys out here have any recommendations?
Thanks!
Thanks!
