What phone, what model, what OS, what version of the OS?????
I'm using a Samsung Galaxy Y, I was running creeds rom on it, but it had some issues (Didn't detect headphones) so I tried reverting to stock... While I was flashing, the progress bar on Odin just got stuck in one position for a very long time, so i interupted that whole flashing process, i know it was stoopid, but that's what happened. Followed ALL the instructions by the way
+Steps How to Unbrick your galaxy y (SoftBrick)
1.Download Odin V1.85 on your Computer Odin3-v1.85.zip - 4shared.com - online file sharing and storage - download
2.Download S5360DDLA1 Android AdvicesGalaxy Y S5360 - Steps to Install Official Global Gingerbread DDLA1 2.3.6 Firmware
After you Install it Extract the Odin on your computer and Click Odin v1.85 and After you downloaded your original firmware, extract it also to your computer..
3.After that shut down your phone and put it on download mode
4.Connect your Android Phone to your PC and Open Odin
5.And u will see a yellow box on the left side it means your phone is connected with the PC
6. Now click PIT and go to your extracted s5360 ddla1 and open that file and select totoro_0623.pit
7.same thing you do on Bootloader, PDA, Phone and CsC
8.now check if everything is done and press start ..
9.wait for the flashing to finish
10. If its finish do not unplugged the usb cable yet until rebooting is done
11. AND NOW..!! CONGRATSS!! YOU HAVE A NEW UNBRICKED PHONE
PIT- totoro_0623.pit
Boot loader: DefaultCalDataWithBoot_S5360DDLA1_REV05.tar.md5
PDA: PDA_S5360DDLA1_REV05.tar.md5
Phone: MODEM_S5360DDLA1_REV05.tar.md5
CSC: GT-S5360-MULTI-CSC-ODDLA1.tar.md5
So I can flash any stock ROM? Or doest this work with only specific types of stock ROMS?Can get to recovery? That's easy to sort then
Take the memory card and put it in a reader or diff phone,download stock ROM .zip and put it on the mem card
Start in recovery and flash from zip
