Polo 9n Gearbox repair advise required
TumeloSharks
I unfortunately have little experience with gearboxes, let alone repairing a damaged one.
Eish, ok thanks though.... i have actually reached out to a friend just now... he says the circled part is replaceable and i will also have to change the bell housing
airborne
Thanks, will do. he estimates that it will cost around R3500 for parts and labor. Just not sure if it's wise to fix or replace it with a 2nd-hand gearbox.
That's a fair price, if the gearbox was 100% before it might be safer to just replace the broken parts on yours.
Make sure whoever does that work knows what they are doing because the impact may have damaged bearings etc. Also ask if there are any known issues with that gearbox, may as well sort them out now when it's all open.
TumeloSharks
Thanks hey, i will go for the repairs.. the gearbox was still in a good condition, I never had issues with it. I will also check for the bearings and ensure that all is still in good condition. Thanks again
