Hi Internet Peeps.
I am in desperate need for guidance on what capacitor I should buy to fix my Asrock Z68 Fatality motherboard.
So I accidentally nudged a Gold cap on my Motherboard, it burst and now having major issues.
In essence, I need to find a replacement Capacitor for a cap that is labeled as: LF 820 e 17A
Does anyone know what cap I can use to replace this? For the life of me, the original Caps are impossible to source.
I have looked everywhere but can not get it!
They appear to be Japanese made caps, So I doubt I will be able to get the same ones.
However, I need to revive my Motherboard.
Any Advice?
P.S - See the image attached, as this shows the Cap in question (PCE16)
Thanks in advance!!
Regards,
Richard
Any Advice?
Thanks in advance!!
Regards,
Richard
