johanhorak
- Oct 11, 2006
I am using a Huawei B68A HSPA+ 21Mbps Wireless Gateway GSM broadband Router
The idea was that the modem with antenna would give me better reception when traveling to remote places.
I am not sure why this modem given the above would give me such poor internet connection.
Why when I add the antenna no page opens on any browser? (I have followed the procedure to activate the external antenna, then switch off modem, add antenna, start modem again).
I hope you can assist.
BTW: This gives you the background for my search for a strong antenna for a 3G WiFi router.
- I have MTN sim from Axxess
- It makes an internet connection at my home in Simonstown
- The connection is poor - very slow - images takes ages on various sites - while it's not an issue using my ADSL.
- I have 3G coverage according to MTN coverage map. My house is on the edge of the 3G map.
- When I use the antenna the connection is practically non existing
(I'll search)
