Port Forwarding help Please!
fromb
I've tried a while ago to open port 3000 on the Telkom Marconi router but even after lots of advise from members here, was still unsuccessful and it seemed to be a problem with the Marconi. I've now replaced the router with a Chronos with a Conexant chipset and is still not able to succeed. Please help!!!
Moederloos
We should be able to help, but will need to know:
What you have done (step by step)?
What do you hope to achieve?
What OS are you using? What Service Pack (if applicable)
fromb
Hi Franna
Yes its me again. The IP is 165.165.167.247 Is there a buildin firewall in the Chronos router? Don't seem to find it in the setup.
Franna
I can ping 165.165.167.247
What exact model Chronos ADSL router do you have.
You must configure port forwarding on the router:
Internal: (LAN)
IP: 192.168.0.110
Port: 3000
Protocol: TCP
External: (WAN)
IP: 165.165.167.247
Port: 3000
Protocol: TCP
fromb
The following info for the router:
BootCode Version: BC_CX82xxx_4.1.0.28
Firmware Version: CX82xxx_4.1.0.29
Customer Software Version: 4.1.0.29b
Under Vertual server on the router I've setup the ports 3000 (Public & Private) and the Host IP to 192.168.0.110. Where do I setup the WAN IP or do I just type it in IE when I try to get in from dailup?
fromb
Have just turned it off and retried but no luck. When I typed in 192.168.0.110:3000 from another pc onthe lan, I get into the server without a problem.
Franna
Then there must still be some configuration error on the modem.
Things to check:
1) Make 100% sure port forwarding is corrrectly setup.
2) Temporarily disable any firewall on the router.
3) Is the router running in bridge/router mode.
4) IP 165.165.167.247 not responding anymore. Is it still listed as the WAN IP.
fromb
1. If I'm supose to set it up in the Vertual Server Config then I'm quite sure it is right
2. I'm unable to find a firewall setting in the router setup
3. How do I check ifit is running in bridge/router mode?
4. After I turned it off and on again, the IP Address has now changed to 165.165.186.178
thedoc!
VTS
Company Rep
I have port 3000 open for my mdaemons' worldclient on my telkom modem, was very easy...
Its very straight forward and was under virtual server.
/doc
Franna
Well - according to the YAPS port scanner port 3000 is not open on 165.165.186.178.
The problem must be on the router, and not on the server or LAN. You also experienced the same problems with your Telkom router. And I'm 100% sure it is a configuration problem - rather than a hardware problem.
Franna
Doc - what is the exact virtual server settings?
Is it as follows:
Public Port Start: 3000
Public Port End: 3000
Private Port: 3000
Port Type: TCP
Host IP Address: 192.168.0.110 (Internal server IP)
thedoc!
VTS
Company Rep
ID Public Port - Start Public Port - End Private Port Port Type Host IP Address
1 25 25 25 TCP 192.168.10.254
2 110 110 110 TCP 192.168.10.254
3 3002 3002 3002 TCP 192.168.10.254
4 3000 3000 3000 TCP 192.168.10.254
This is how I have bound mine - works a charm!!
/doc
fromb
I've just put the telkom router back to try it doc but now I can't remember what the standard password for it was. Can't find the docs. Can you help?
Franna
User: admin Password: root
User: root Password: root
User: admin Password: <blank>
User: admin Password: 1234
Fromb - Also add port 3002 to the virtual server settings.
3 3002 3002 3002 TCP 192.168.0.110
4 3000 3000 3000 TCP 192.168.0.110
This should also work on the Chronos router. Just get the new WAN IP after every reset of the modem.
thedoc!
VTS
Company Rep
I honestly dont remember the password - but guessing it was admin and <blank> i.e. nothing.
I changed mine for obvious reasons..
/doc
fromb
Hi Doc
I Just tried seeting my router the same except for the Mdeamon server IP and router LAN IP which is 192.168.0.110 and 100 but still no luck. Please could I contact you by phone so you could help me through it?
thedoc!
VTS
Company Rep
Sure Ill call you from my VoIP, I am out of the country now :) PM me your number..
/doc
musan
do you by any chance have the dhcp server still running and serveing the internal boxs its ip ?
this should only cause problems after a while though.
what network probing tools do you have ?
are you on a stable ip ?
