AdrianH
- Feb 27, 2005
Hi
My inverter generator's fuel tank sprung a leak over the weekend when I started the generator. Upon inspection I saw the generator's plastic fuel tank split on the seam for about 1 1/2 cms. I decided to use Pratley Wondafix rather than Pratley Putty as the Wondafix allows for some flexing and probably handle the vibrations better. I applied the Wondafix to the outside of the tank with about 1cm around the split seam.
I have yet to refill the tank but now I am worried that the petrol will react with the Pratley Wondafix and maybe dissolve it, something I didn't think of over the weekend. Does anybody have insight or experience with Pratley Wondafix and how it will react to petrol?
