Electronaut
Hi All
I recently had a power surge at my place which killed my router - a D-Link 2540U. I've subsequently replaced it with the same model [although the physical router does look different].
I have four different ADSL accounts that I previously connected to, with one local only acc details logged into the router itself & the other three connected to via PPPOE 'Broadband' connections.
PROBLEM: Since the new D-Link 2540U has been connected I've not been able to connect the PPPOE self generated accounts. Message received is "Connecting through WAN Miniport [PPPOE].. Error 678: The remote computer did not respond"
I've done a manual reset [with pin behind router] & re-entered settings provided by ISP with no difference. I'm on a PC running XP SP3
Any advice would be greatly appreciated.
Thanks in advance.
Thanks in advance.
