I have had 384K ADSL for the past 2 weeks. I've been running IPCop with an ADSL PCI modem (Conexant) and its been working fine from day 1.
My connection suddenly dropped last night with the following entry in the RED (modem) logs:
I have "Persistant Connection" activated, so it tried to dial up and the following was logged.
I then called my ISP this morning. They say they dont have a problem and their side, but said that they noticed that an "Edge Router" was down and I should call telkom. I did , and after trying to explain that I DONT use a Telkom Router but IPcop... (sigh)....they decided to log a fault.
They also gave me a Telkom ADSL guest account to try....Nothing doing.
If they send a technician out here and the problem is on my side, I would have to pay for the callout. I'm just trying to avoid that, so if anybody has any advice......it would appreciated.
If I try to dial up now, the error logs I get is as follows:
Absolutely nothing was changed on my side. I was actually using the connection when it suddenly dies.
Any advice would be appreciated.
Code:
20:11:26 pppd[404] LCP terminated by peer
20:11:26 pppoe[406] Session 20487 terminated -- received PADT from peer
20:11:26 pppoe[406] Sent PADT
20:11:26 pppd[404] Modem hangup
20:11:26 pppd[404] Connection terminated.
20:11:26 pppd[404] Connect time 1440.4 minutes.
20:11:26 pppd[404] Sent 4245018 bytes, received 28036040 bytes.
20:11:29 pppd[404] Exit.
Code:
20:11:29 red: Connectioncheck will connect again
20:11:29 red: CnxPCI ADSL starting
20:11:29 red: CnxPCI ADSL already loaded
20:11:29 red: CnxPCI ADSL waiting for sync
20:11:31 red: CnxPCI ADSL sync done
20:11:31 pppd[5911] pppd 2.4.2 started by root, uid 0
20:11:31 pppd[5911] Using interface ppp0
20:11:31 pppd[5911] Connect: ppp0 <--> /dev/pts/0
20:12:06 pppoe[5912] Timeout waiting for PADO packets
20:12:06 pppd[5911] Modem hangup
20:12:06 pppd[5911] Connection terminated.
20:12:06 pppd[5911] Exit.
20:12:10 red: Connectioncheck RED fail to connect
20:12:10 red: CnxPCI ADSL stop
Code:
12:02:33 red: CnxPCI ADSL starting
12:02:33 red: CnxPCI ADSL already loaded
12:02:33 red: CnxPCI ADSL waiting for sync
12:02:35 red: CnxPCI ADSL sync done
12:02:35 pppd[3929] pppd 2.4.2 started by root, uid 0
12:02:35 pppd[3929] Using interface ppp0
12:02:35 pppd[3929] Connect: ppp0 <--> /dev/pts/0
12:03:10 pppoe[3930] Timeout waiting for PADO packets
12:03:10 pppd[3929] Modem hangup
12:03:10 pppd[3929] Connection terminated.
12:03:10 pppd[3929] Exit.
12:03:13 red: Connectioncheck RED fail to connect
12:03:14 red: CnxPCI ADSL stop
