Qaulity of Romoss power banks
francois072
I'm thinking of purchasing the Romoss sense 4 mini or the Romoss Ares 10 but I don't know if they are good quality. The reviews on Takealot don't really help much. Any advice is appreciated.
Genuine ones are fantastic but there are a load of fakes out there.
If sold directly by takealot then should be fine but if it's a third party seller don't risk it.
SureThing
Which one will hold enough charge for a 5 day hike..charging a gopro battery and cellphones x2?
francois072
I'm happy with mine. It's the one power bank I have that I can use while it charges.
@Dan C can vouch for them too I believe.
Which model do you have?
What is the size of your phone's battery?
How many charges do you get?
How long have you had your's for?
Gadget Man
I have the LT20 20000mah unit. It's heavy, can charge my Samsung A70 5x. Holds the charge and reliable. Takes long to charge even with a quality fast charger.
IssiAmd
Have a sense 4 for about 3.5 years now
No problems, still running
francois072
Any other recommendations on affordable power banks in ZA?
Superfly, LDNIO, Ultra-Link and Rocka may be options?
francois072
I'll purchase it from Takealot but also make sure to check the authenticity. Romoss has an article all about fakes.
IssiAmd
Actually a better word would be real life performance.
Like the amount of charges and so on
Can't say exactly unfortunately.
Don't think I've ever charged my phone on the bank from zero to full and definitely not multiple times on one full bank
I estimate I should get two charges on my phone though.
Phone has a 4200mah battery.
The romoss served me much better than a Samsung fast charging unit I bought around the same time.
Sammy folded in less than a year.
francois072
My phone has a 3200mAh battery so that's fantastic news.
Steamy Tom
my 20000 charge my phone like 2-3 times easily. a 40000 is probably what you want
killerbyte
I have my 4th Romoss power bank. Not because they die, but because I just see a new shiny model and I want it.
So far I have bought:
Sailing 4 10,000 mAh
Polymos 10 10,000 mAh (Lithium Polymer battery)
Sense X 10,000 mAh (Fast Charge)
Sense 8+ 30,000 mAh (Fast Charge , USB C and Lightning charge support)
