R1500 to replace 4 brake pads - expensive or not?
PsYTraNc3
Nope. I would say that's about right...
My car is under maintenance plan but I still get a copy of the bill.
I saw just over R800 per set of break pads. 2014 i20
R13...
Sounds low actually, I'm I paid at least R1200 to replace my front pads at VW on a Polo
Nick333
It's ridiculous tbh. The pads would probably cost R300 max at Midas. Never go to the agents for anything.
saturnz
yes but consider the labour, it will take an hour to replace the front and an hour to replace the back.
and perhaps the discs also will need to be skimmed
Sinbad
Front axle on my car - R4500 at an indie. Pads only.
/cry
Nick333
It would take you or I an hour perhaps but some grease monkey that does that sort of thing day in and day out shouldn't take more than 15 minutes and that's no exaggeration. Skimming brakes is not something you generally have to do when changing pads - it's a whole other thing and you'd be paying way more than even the OP did.
Sonic2k
Excellent price... that is what it costs me in parts alone to DIY on some of the vehicles we own
Neo_za
I still find it weird that some guys replace brakepads at stealerships after the car is out of motorplan, no car experience is required to do thse type of jobs, spareshop + a visit to Tops@ spar on a sat morning..thats all you need, a set of size 12 - 18 costs 80 buks or less
Fox1
Some cars require "special" allen keys to open the pads.
ToxicBunny
Oi! Leave me out of this...
Hour to replace the front and an hour to replace the back?
Have you ever actually changed brake pads yourself?
ToxicBunny
If you don't have the right tools, it can easily take more than that.
For an amateur yes maybe.... though there is always a "boer maak a plan" type tool if you don't have exactly the right ones.
For a mechanic no more than 20 minutes front and 20 minute back.. (if its brake pads all around)
