R15000.00 to linux dev will to help resolve a Ubuntu 10.04 KVM issue with XP Pro.
IamIvan
Hi Guys,
I am a PM for a rather large IT vendor in SA.
I am URGENTLY looking for a senior linux dev who can assist with the following: The issue I am facing is that the generic VGA driver being used in KVM for guest OS XP does not support 1366x768 resolution. I NEED THE FREAKIN 1366*768 resolution to display properly in the guest os.
My client is running ubuntu 10.04 which works PERFECTLY with 1366*768 resolution. The moment they switch to the KVM Xp Pro , 1366*768 is not a selectable resolution. I need the guest OS to support the 1366*768 resolution.
I need URGENT assitance for someone to resolve this issue, I am aware that there is some development involved. I am willing to pay R15000.00 (fifteen thousand rand) to any senior dev who can help us resolve this issue. There will be some terms and conditions involved of course.
Please drop me a mail if you are interrested. Please , no nubies , I dont have time to screw arround , I need someone professional who can resolve this issue.
If you are interested, please mail me on ivan.barnard@gmail.com
Regards,
Ivan
bleh69
thats a lot of money for pixel problem. how will you pay? cash or card?
jeanres
uhm 50% upfront and I will help you..... if I can't you get your 50% back! :) I keep the pickles though
IamIvan
No upfront deals. We will do either cash or EFT whichever way you prefer.
Bottom line , I need a solution and I need it yesterday..... 20 years ago.
icyrus , thanks for the info, been there tried that with no results. Thanks anyway.
F
Fudzy
Guest
Is it ONLY that resolution that can be used? Wouldn't it be cheaper just to buy another LCD with a supported native resolution?
IamIvan
odd ball resolution , it's on a notebook with a HD ready screen , native Ubuntu 10.04 runs perfectly .....the crap begins with KVM and guest OS XP pro...HEADACHES ...oh the freakin headaches !!
IamIvan
been there tried that. in fact brought in 3 different lcd panels.....seems that KVM does not like any widescreen notebooks.
jeanres
oh btw set X to 16bit not 24bit :) driver limitation it should work 100% then
Peon
If I may ask. Why do you need development? Because you're a vendor? Im pretty sure a workaround will work now but not if youre a vendor.
IamIvan
I am looking for a short term solution. 99% of our support is based arround Microsoft. When it comes to linux....well ...things become interesting.
MyWorld
If I may make a suggestion, PM koffiejunkie and milomak, between them you should be covered. They have proven themselves here on this forum many times over.
If this was a "home" issue I would have loved to help out, but since you need professional help they are the ones I would turn to.
Sgt.Romeo9
