Rain 5G Unlimited: Speeds like basic home dsl packages, 1000+ ping and no port forward.
ILoveGames
How is this even acceptable by ICASA just to pass them? The port forwarding problem should have not let them even get passed.
Jimmy
Move to where you are satisfied. No one's forcing you to use them.
What an ignorant turd. Don't you see all the issues rain is giving most people? Your comment is not needed.
Edit: Anyways... My connection has been great before 08:00 (300mbps+) then after that I've been getting extremely high pings and slow speeds with constant disconnects.
thecarblogsa
Exactly the same this side.
NeonNinja
Neon Resident
Ignorant turd? I've been using RAIN for close to 2 years. I stopped when they did not seem to fix things or care. And moved. Of recent as well the level of service and customer service has declined with the number of users they've been amassing.
ngoni615
I will be stopping payment because i moved to fibre so i will keep the rain sim card as backup when i need it (granted i always had good speeds 60megs+ download 30megs up) i agree with @NeonNinja , if you are not happy, move on to other providers. I moved on to fibre despite rain's good speeds in my area because i wanted better and consistency.
Jimmy
At least you guys are fortunate enough to have the option to move to Fibre. I can go back to ADSL but screw that.
ngoni615
If ADSL was working fine and better than lte then it only makes sense to go back to adsl.
