Registry monitor/cleaner
LandyMan
Hi all,
I am looking for a (pref freeware) program to monitor changes to my registry, and that can also do scans of the registry every now and again to clean it up a bit.
I have seen Regcure, but it costs money
Cheers
xenithon
Crap Cleaner - not for monitoring but brilliant for system & registry cleaning.
Leonard Chowns
Regseeker
I use Regseeker!!!! But listen very carefully!!!! You can crash your system if you accidentally delete any pertinent registry file.So I would not suggest Regseeker unless you are very confident that what you want to erase is not a necessary component. Lenny
I also agree with.geek CCleaner is awesome, But keep it updated. Only use the update to see if you have the latest version. I would not open any ( message for you and/or You have won a prize)
