remote desktop help
dd1313
Hi Guys
I have a lan of 7 PC's a HUb and my ADSl router.
the usernaname and password is in the router and I am permanantly connected to the net.
How can I access one of the PC's on the lan via remote desktop from my home please
DD
Juggy
You need to create a PAT rule to forward requests on port 3389 but first you'll need to signup with dyndns.org so you can get a static presence.
Highflyer_GP
Open remote desktop connection from communications, which is in accessories. Expand the options button, select the computer that you want to connect to, type in the domain name, username and password.
mancombseepgood
Use Hamachi
Use Hamachi
www.hamachi.cc
instructions included - it's an EASY to use VPN client - no worries with firewalls, routers etc. Works like P2P and free. Once Hamachi set up, you can use any app you normally use on your LAN as if you were on the same network (using the IP address in Hamachi).
dd1313
Thanks.
Ok so I get an account with a dynamic dns provider and then
how do I create the PAT rule please
thanks again
DD
Beta
Banned
Enable remote desktop:
Right click My Computer-select properties-enable remote desktop-grant users permission.
Control a sysytem with remote desktop:
Start-programs-accesories-communications
Click remote desktop to launch RD CLient
Enter name or IP of machine(10.0.0.9 etc)
Click connect
Logon
Configure exeption in firewall(if using one)
Straight from 70-270 manual.
