Apologies if this has been answered before, but I couldn't manage the right search words to find an answer.
What are the reuse possibilities of WiFi equipment? Do the WUGs use the same equipment as most WISPs?
I'm planning on buying a,
* 2.4 GHz antenna
* PoE unit
* WiFi router
but I don't want the equipment to be totally useless if I move or maybe switch to another WISP. Will this be a problem or can these items be reused?
* 2.4 GHz antenna
* PoE unit
* WiFi router
