- Jul 22, 2003
There should be decent redundancy on all the links.
Antowan: It is good; I wish more (supposedly) ZA sites were locally hosted --- nothing annoys me more than when .za sites bug out while trying to load google/adsense ads.
GAH!
May I recommend you adblock all such ads?Antowan: It is good; I wish more (supposedly) ZA sites were locally hosted --- nothing annoys me more than when .za sites bug out while trying to load google/adsense ads.
I think you're mistaken. Just about everything about Telkom seems redundant if you ask me.Steady now - this redundancy concept is still new to Telkom.
I have to thank google for buying out tons of ad companies and using a single url with which they load the ads from...
...Makes it so much easier to block them all with a few lines added to the hosts file.![]()
I'm aware of this, and am mostly quite happy to load ads, but the situation of being capped to local only bandwidth is something that I'm not *ever* going to be happy about --- when I'm on IS local only I'm going to feel very little for those blocked advertisers.
An Ashburn (USA) SAIX link failed on the 14th of August at 14:00 hours
Whatever bug caused the the problem certainly had precise timing - down at exactly 2pm![]()
