Samsung Motherboard / CPU Repair
Marnitzv
Hi All,
I am looking for a company that is able to repair a Samsung Mini S3 Motherboard or CPU Pins.
I had the phone in to a local repair shop and at Samsung but they are unable to fix the motherboard but only replace.
According to the local repair shop, the CPU pins mightbeen damaged.
I would like the phone just to switch back on and be in the current state before it got broken.
Could someone perhaps point me in the right direction?
genetic
CPU pins on a cellular motherboard? Someone is bullsh*tting you. All components are surface mounts. i.e no CPU pins.
Mobile motherboards are usually not repairable. It will have to be replaced.
dsimonse
How does one break CPU pins? If you're having problems with the motherboard of a cellphone its better just to replace it. There are loads of phones out there that's better then your current S3 mini.
Marnitzv
Thanks for the replies... my phone fell 3 floors down. I need the phone in it's current state to recover lost msgs (What's app) .. My msgs were not backed up on google,memory card or the phone. I did some researched and noticed i can do a recovery but i need to enable the developer's option on the phone. Is there someone or somewhere i can take the phone?
Messugga
You'll have to chat to a data recovery specialist like Southbit. They ought to be able to connect to the memory chip directly, read it and maybe recover whatever is on there. It's going to be an expensive exercise though.
