Samsung S6 Car Holder + Charger
Forza
I'm looking for a car holder and charger. I've seen this ultimate Samsung galaxy accessory pack and wanted to know by anyone that has one if it is any good.
http://za.mobilefun.com/the-ultimate-samsung-galaxy-s6-accessory-pack-52258
If not the one in the above link what do you suggest? Do you prefer the one with the air vent than those that attach to the windscreen especially since the phone get quite hot when charging it. Perhaps the air coming from the AC could cool it abit?
http://za.mobilefun.com/olixar-invent-pro-universal-air-vent-car-holder-46749
If I go buying it separate which makes would you suggest for the Car Holder and Car Charger?
blowdart18
I bought the Samsung original accessory from the Brooklyn Samsung store, the guy even gave me some discount.
The one I have allows for wireless charging, output amps from the cigarette lighter is the same as the original USB charger. And the docking station is the same as the wireless desktop charger.
Downside is that wireless charging takes more time to charge especially when using apps like waze. You can however plug directly into the phone and skip wireless charging if you need more power.
Also it sticks onto the windscreen so it cuts out windscreen view especially in the Ford Ranger for example, took time getting used to it being there.
Otherwise it's a nice to have.
