saturation problem solved?
slimothy
Banned
Not sure if this info has been posted here before but whilst checking voice messages on my old sim card I noticed a message from someone at WBS called Johan. He was doing a call back because of the bad international speeds I got last month, he said the problem was saturation and that they were putting up 10 towers (or something to that effect).
I have notice that there wasn't the same 1st of the month slow down this month that there was previously.. so is the saturation problem solved? Any thoughts?
Simple Twist Of Fate
heh, Slim your very own tower ???
with fixed IP for to ensure whois? wow:)
awesome....dude
/me wishes i was so privelgedlyfamous
slimothy
Banned
yes ic my local was fine and international sucked, for a while, i mean it got better at night as expected. He didnt say the towers were to solve the problem on thier own but it stands to reason that they must have done internal upgrades to handle more international traffic and then on top of that put up new towers.
but yeah the network was saturated at the gateway and not just at base stations or it wouldnt have affected so many
Andre1
Johan contacted me last month to help me with bad speed and sort out some other problems. He then already mentioned to me about the filler towers that they are busy installing. He also helped me with an external antenna and I must say since I'm using the antenna, I have no problem. My problem was that I am down in a valley and that the signal go right over me and bounce back from a block of flats. No I don't have any problems. 15 days on-line and still going strong without any disconnection.
Crash
I'm not sure whether to laugh at this or not, but could it be because a number of people have left iBurst = More Stability and Speed ?
No idea.
nocilah
Banned
yea it seems iburst has improved over the last three weeks... i have had no real issues except when the do the odd thing here and there when doing some maintenance...
speeds are allright tonight... i am not unsatisfied and still light years ahead of sentech, my old service provider.
8321
Do you think they know myadsl is doing a speed test this week????
nocilah
Banned
i doub it... they dont even know when certain things on their side is happening or not.
GuRu
Speeds last night were good but today 15H00 seems to be very slow pages taking long to load. Even tried shutting AV & F/wall down to see if that was the problem. :cool:
