Scatec's solar and battery projects in Northern Cape reach financial close, construction starts
Danie_V
So power can be generated for the grid without taxpayers having to cough up billions of Rands, nor does it take 8+ years, and ends up being double the original budget!
Danie_V
Most power sources need parts being replaced, its called maintenance.
Yes, but that maintenance is also proportional to the amount of mechanical and moving parts where there is wear and tear. So I'd expect wind turbines to have a lot more maintenance compared to solar arrays, as an example. Another added advantage of both solar and wind, is the ground underneath can still be utilised for farming without lots of air pollution either...
