Searching for manual HP8350!
Mortymoose
Yes! I am lazy.......
Cpuid tells me that me motherboard is a HP 8350.....
On the HP website I cannot find a manual for such a board.....
I scoured the vastness of the World Wide Web to no avail.....
I think I might have burnt the manual that came with the board on one of my drunken bonfire nights!
Can anyone out there point me to the online manual......
I am way to weak to unscrew the five screws on the PC to do a physical check of the boards ID, but suspect Cpuid is lying to me again!
I thank you.....
/moose now tired after all that tikking! :confused:
Willie Trombone
Fx8350 is likely the AMD CPU.
Install Belarc Advisor, run it then "print" the resulting output to PDF, stick on Dropbox, one drive or other file share app and pm the link and I'll see what you have.
