Hi, I got a E220 modem (USB), installed the 32K (didn't have 64) sim card, it eventually picked up (on auto) the Vodacom network 24 hrs later, and is receiving sms without problems. Signal strength indication ranges from 3 to 5 bars, depending on where I am in the house. However, I do periodically get a total disconnect (No Network). This is in Sunnyridge, just south-east of Bedfordview. The coverage map in my area shows no 3G, but tests with a datacard before I got the E220 showed generally good (up to more than 1.4 Mbps) data transfer rates on occasion.
OK, so the problem: using the default Vodacom connection (APN: internet, authentication number: *99***1#, no user id or password), the connection fails. It starts transmitting the packet, then says: A connection to the remote computer could not be established, so the port used for this connection was closed.
I only have the normal Windows firewall installed.
Does anyone have an idea what's going on? I checked out the huawei web site, Vodacom, Google, this forum... next step is the 155, but - I understand I must set some time aside for such a big venture ;-)
enjoy, and best regards
Pieter
Pieter
