Signal Level Meter for Novatel card
cyberbob
Hi,
I've written a little win32 based app (to use with the new high gain antenna), that will monitor the current signal level while you "wiggle" the antenna around :eek:
Anyway, it's basically untested (except on my laptop), so don't be suprised if you run it at this stage, and find it does even detect your card (basically the only part the might not work ... I think)
Try not to be too harsh with comments, but let me know.
Here is the link (not sure how long it will be here for)
http://srva.red24.info/robert/ftp/sigmeter.zip
nicovdw
Works great
Thanks,
It works great here. Now I also know how to interpret the CSQ replies :)
I will be building my antenna sometime this week, and post my results.
vodacom3g
Vodacom Representative
There's a nice project for the forum, custom-built antennas!
Maybe rpm can sponsor a price for the best performance/cost ratio unit.
Only problem will be the little connectors....
vodacom3g
The others are still busy rebuilding their notebooks after installation....:)
Just joking, sure it's going to be a winner!
By the way what is a Singal Level Meter? :confused:
NeBo
@cyberbob: Thanks for your efforts. Have a negative response for you. When i run the app, it "fails to open port". Any ideas?
Primary port is COM4
Secondary port is COM5
nicovdw
Make sure you are not connected when you open the app. It works fine if the crashboard is open though.
NeBo
Yes but is logical that if the port is already open, then your app can't obviously open it again. duh. But anyway, it works really well. Thanks cyberbob. Stylin job. :) :) :)
ajax
...asks he who says:"Maybe rpm can sponsor a price for the best performance/cost ratio unit. :D
ic
MyBroadband
Super Moderator
vodacom3g said:
ic, maybe you can merge this thread with the dialer sticky?
I think that might get confusing since they are separate applications, there should be separate threads to discuss aspects of each application in isolation from the other [unless at some point in the future the applications merge and become one].
What I will do instead, is to create a new sticky thread, that has links to the separate threads for both applications, and if more applications get written, a link can then be added to the one sticky thread :).
goodgirl
That's so cool, I just downloaded it and started it without any 3G card inserted and without VMC started, it still said it detected the card. Maybe it just detected that I have the driver installed, not the actual card present:
Checking for precense of Novatel U630 datacard ...
card detected
Trying to detect primary Novatel Port ...
port detected
Trying to detect secondary Novatel Port ...
port detected
opening communication port ...
failed to open port
card inserted, VMC not open:
card detected
port detected
port detected
port opened
With the little antenna on the side of the laptop screen I get:
CSQ 9 -95 dBm
When I unplug the little antenna:
CSQ 4 -105 dBm
VERY NICE, so cool to see the little free antenna making a difference !! :)
I would change "precense" to "presence" in the application.
Are you making a version for Option cards, too?
vodacom3g
cyberbob,
If you're up to it, I'll lend you an Option Colt card, if you would like to add support for it in your Level Meter?
I can do the same for all new cards, if you can find the time.
cyberbob
Yeah, I don't mind :) ... any chance to "play" with "new toys" :D
I've been using the antenna for a few days now, and it difinitelly does help a lot!!!
