I went the PV way with a geyserwise.As above, want to convert my 150l geyser to solar. I see there are two very different systems available. The PV option appears by far better: no pump/moving parts. But perhaps I'm missing something..?
If you plan on going full blown solar then do not go this route put that money towards your solar set up otherwise PV is fine just ensure there is NO shadeAs above, want to convert my 150l geyser to solar. I see there are two very different systems available. The PV option appears by far better: no pump/moving parts. But perhaps I'm missing something..?
Why not evacuated tubes. They are efficient and take less roof space.I also considered the evacuated tube conversion until I spoke to people that went that route.
PV all the way
As stated above, main reason is that the R14k for conversion (for 150l) is much better spend towards budget for a home solar solution.Why not evacuated tubes. They are efficient and take less roof space.
If you build your home from scratch this would be something to consider. Most setups already have a 220V geyser that's in working order.Why not a heat pump + solar system?
if you plan your system properly you can go full blown solar for your oven and go induction for your stoveIf you build your home from scratch this would be something to consider. Most setups already have a 220V geyser that's in working order.
But then I would rather go gas for water and cooking/baking.
Whats the pull from your mining rigs? I see your base load is around 1kwif you plan your system properly you can go full blown solar for your oven and go induction for your stove
Geyser needed quick top up in the morning and made dinner in oven and induction stove
My overnight base load looks like thisWhats the pull from your mining rigs? I see your base load is around 1kw
Perhaps good suggestion but I just spent $$$ on 5kW inverter with 14kWh batteries + 2kW panels. So it could be a bit too late...If you go the PV route for water heating stay away from special solar PV geyser heating elements and MPPT converters. Rather spend the money on a decent hybrid inverter (e.g. Sunsynk/Deye) and PV panels so that you can feed 240V into the geyser instead. That way you can use any excess power for other household loads besides the geyser and you can expand later without changing anything. Also you can use standard geyser elements if one fails and not expensive DC elements which are expensive to replace. 2000W 240V elements are also available and cost around R400 at Builders in case you need to reduce the peak power requirements.
do you get sufficient sun to charge up the batteries? or you plan on expanding that as your batteries seem disproportional to your panelsPerhaps good suggestion but I just spent $$$ on 5kW inverter with 14kWh batteries + 2kW panels. So it could be a bit too late...
