leon.davibe
- Feb 3, 2009
imo the goal isn't to carry everything overnight, though if the budget allows a person can go there, working towards thatNot sure exactly how much.
It starts taking solar-charge from about 09:00 and I have it set to cut back back to discharge when it reaches 60%; the current 200Ah-48v battery is full latest 14:00. This is on days when my Domestic is here, using the Dishwasher/Dryer/Washer/Vacuum/etc.
My problem is with how much I can store and what extra I need to not have to worry about it running out by 22:00-ish, whilst also not being conservative with usage. I've calculated that another 200Ah battery could take me to 04:00 or so.
If I upgrade to 800Ah+ battery storage, I will be able to run completely independent with abundance. I'll probably also need 4 more panels to get the batteries pumped when it's cloudy.
the goal is to use whatever you can produce at the moment
how big is your solar array
how much do you produce
then you can estimate how much you are losing
and decide if you want to spend the money to grab those losses
