some math help please
ichocolate
HI,
I forgot this stuff and feel terrible and useless.
I need to find out what is the % value of each amount of units ..... that make up a pie.
so of the pie for example... i have a few items or categories....
So for each value below how to work out what they represent in the pie.
I forgot how the hell u do this:
15 000
75 000
90 000
200 000
do u say 15 000 / 100 ; and 75 000 / 100 ; and 90 000 / 100 ; and 200 000 / 100 ?
but then i dont know what the hell to do next.
I dont know how to search this on google or youtube even because i know what the hell u call it
Please help,
Pox
(Piece of pie / Total of all the pie) *100 = percentage for that piece.
cguy
The sum of them all is 380 000. The 15 000 value is therefore (15000/38000)*100 percent of the pie (~4%). etc.
Drifter
You need to sum the units and then calculate the percentage of the unit against the sum.
Venomous
(Total of all the pie) ÷ 100 = percentage for that piece.
FTFY
Devide not times by
That will give you the value/% of 1 unit.
After that you need to calculate the various segments.
There are fomulas to calculate this.
Daruk
HI,
15 000
75 000
90 000
200 000
Please help,
15 000 + 75 000 + 90 000 + 200 000 = 380 000
15 000 / 380 000 X 100 = 3.95%
75 000 / 380 000 X 100 = 17.74%
90 000 / 380 000 X 100 = 23.68%
200 000 / 380 000 X 100 = 52.63%
For verification: 3.95 + 17.74 + 23.68 + 52.63 - 100% (well 98, but they're rounded so they won't be exact)
braniac
Hi. If I'm understanding your question correctly this is my solution.To work out % eg 15000.
15000/380000*100=3.95%
To work out degrees on pie chart eg 15000
15000/380000*360=14.21°
Where 380000 is the sum of 15000,75000,90000 and 200000.
Hope this helps.
ichocolate
Add up all those slices of the pie and devide each slice by the total
Hi,
Thanks these were the most understood.
Regards
James
Drifter
DEFINE DATA LOCAL
01 #N-TOTAL (N6)
01 #N-UNIT (N6)
01 #N-PERC (N3.2)
END-DEFINE
#N-TOTAL := 380000
#N-UNIT := 15000
COMPUTE ROUNDED #N-PERC = (#N-UNIT / #N-TOTAL) * 100
WRITE 'ANSWER = ' #N-PERC '%'
END
Run
ANSWER = 3.90 %
ichocolate
DEFINE DATA LOCAL
01 #N-TOTAL (N6)
01 #N-UNIT (N6)
01 #N-PERC (N3.2)
END-DEFINE
#N-TOTAL := 380000
#N-UNIT := 15000
END
Run
ANSWER = 3.90 %
in Pascal?
please send me the .pas file?
ichocolate
Hope this helps.
Sorry sometimes i ask the questions in a shitty rush.
