Spec's as per user Manual
<u><b>ADSL Standard</b></u>
Each ADSL Router series supports either one of the ADSL standards below:
<i>1.</i> ANSI T1.413 Issue 2
<i>2.</i> ITU-T G.992.1 (G.DMT)/G.992.2 (G.LITE) <b>Annexure A</b>
<i>3.</i> ITU-T G.992.1 (G.DMT)/G.992.2 (G.LITE) <b>Annexure B</b>
(ADSL over ISDN for Europe)
<i>4.</i> ITU-T G.992.1 (G.DMT)/G.992.2 (G.LITE) <b>Annexure C</b>
(ADSL over ISDN for Japan)
<u><b>Ports for Connectivity</b></u>
<i>1.</i> One RJ-45 for 10 Base-T Ethernet
<i>2.</i> One RJ-11 for ADSL line
<i>3.</i> One AC power jack for power supply
<u><b>LEDS</b></u>
<i>1.</i> POWER - Power indicator
<i>2.</i> DSL_LNK - ADSL Link indicator
<i>3.</i> DSL_ACT - ADSL Active indicator
<i>4.</i> LAN_LNK - Ethernet Link indicator
<i>5.</i> LAN_ACT - Ethernet Active indicator
<center><u><b>LED functions</b></u></center>
<i>Paste the following into a text file, save it with a .htm extension
and then open with your browser.</i>
Code:
<table width="80%" border="1" cellspacing="0" cellpadding="2">
<tr>
<th width="19%">Label</th>
<th width="14%">Color</th>
<th width="23%">On</th>
<th width="19%">Flash</th>
<th width="25%">Off</th>
</tr>
<tr>
<td align="center">POWER</td>
<td align="center">Red</td>
<td align="center">Power On</td>
<td align="center">N/A</td>
<td align="center">Power Off</td>
</tr>
<tr>
<td align="center">DSL_LNK</td>
<td align="center">Green</td>
<td align="center">ADSL Connected</td>
<td align="center">Off Line</td>
<td align="center">ADSL Disconnected</td>
</tr>
<tr>
<td align="center">DSL_ACT</td>
<td align="center">ADSL Active</td>
<td align="center">ADSL Idle</td>
</tr>
<tr>
<td align="center">LAN_LNK</td>
<td align="center">Ethernet Connected</td>
<td align="center">Boot</td>
<td align="center">Ethernet Disconnected</td>
</tr>
<tr>
<td align="center">LAN_ACT</td>
<td align="center">Data Active</td>
<td align="center">Ethernet Idle</td>
</tr>
</table>
<hr noshade size="1">
If at first you can't download, try and then try again...
