Speed of Telkom Router
HR
Hi
Our Telkom Router Pots is connected to a 3com/10/100mbps switch.
Acording to the switch the speed is only 10mbps.
The fly lead is brand new.
Can the Telkom Router only do 10mbps?[?]
BTTB
Did you test the cable on another machine yet>
<b><hr noshade size="1"></b><font size="2"><font color="red"><b>You can take Telkom out of the Post Office but you can't take the Post Office out of Telkom.</b></font id="red"></font id="size2">
HR
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by BTTB</i>
<br />Did you test the cable on another machine yet&gt;
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Yes it do 100mbps on other Pc's.
BTTB
Ok, then Im not sure as I use a Zyzel and although it has a 10 and a 100 led light, it always settles on the 100.
My comment about the cable was more relevant to my own experience when making my own cables. If one of the wires is wrong when you crimp them you might get only 10Mb transfer on that particular cable.
Andre
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by HR</i>
Yes.
HR
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Andre</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by HR</i>
Yes.
but
That sucks.
Are there Telkom routers availible that can do 100mbps?[?]
Andre
They only sell the one router that I'm aware of.
BTTB has mentioned the Zyxel and the Netgear is another modem I'm aware of that does 10/100.
Mean_Monster
The question I have is what difference is this gonna make[?] Okay a faster connection to the router but it will not influence the browsing speed, if anything minimal. The router would basically be able to send data to your computer faster, but it is still receiving it very slowly from the internet side.
The bottle neck is still going to be your 512K line[?]
Am I missing something[?]
Andre
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Mean_Monster</i>
It won't matter with the DSL speed, but if your router has a built in hub with 100mbs and you have a couple of PC's connected up directly to the router, it speeds up things like large file copies.
antowan
It does not matter much. The bandwidth it has to deliver is a 20th of what the cable is giving you. The speed between PC's is what matters.On your LAN that is. The network speed from the ADSL router will never be more than the bandwidth Telkom provides...
Cheers
He who does not understand the value of war at the right time, cannot comprehend the value of life at any time - Anonymous
