Speed Tests
nonroker
Hi,
I just did some speed tests with iperf to a server overseas.
With UDP I get 258kbits/sec
With TCP I get 129kbits/sec
I ran the tests 3 times each and it always comes down to those numbers...
I'm on the 256k package.
Are we being shafted here by the new bandwidth management system?
Brolloks
Question is: Is the new bandwidth management system working? How are they managing it?
regardtv
From the looks of things the new bwm is very much still in process ....
nonroker
My previous test results started to make me wonder.
So I setup the iperf server to run on my side, and connected to it from the other side. (The previous results was only sending speed ie. Uploads)
To my surprise I got 229 kbits/sec to my pc in UDP mode, but only got ACKs on 78% of the packets sent.
In TCP mode I got a shocking 38 kbits/sec!!! Even after I switched off Nagle's Algorithm (This is where TCP backs off when it gets packet loss)
My next test is now to setup a udp tunnel to the box overseas and check the results of these tests running across that tunnel.
nonroker
Ok, here are the results....
I set up a UDP openvpn tunnel to the box and ran the test again.
This time I'm getting 80 kbits/sec on TCP to my box, and 220 kbits/sec from my box to the other box.
That's quite a big jump, still nowhere near 256k.
The openvpn overhead chows some of the bandwidth though...
One advantage of the openvpn tunnel is the optional lzo compression which gives a nice speed boost for web browsing (tested at 416 kbits/sec using iperf) [:)]
