Strange lan Problem
Jarrod
Hiya, we have 2 offices and both have a 4mb/s connection. Something that I have noticed from this afternoon is that I cannot get on to certain WebPages from the the non ADSL server machines www.fnb.co.za is one of them. From the server machine it connects no problem but from the other machines on the LAN it doesn't. I thought I broke something so I went to the other office across town and went there to see if I have the same problem and I had. One LAN has 5 machines and other LAN has 3 machines both on USB ADSL modems. Using webafrica prepaid on bouth connections.
Does anyone have the same problem and if u did what did you do to fix it?
Thanks in advance
Jarrod
Jarrod
Ok just made some an very interesting find. If i change from the webafrica saix account to and IS account the problem goes away and i have access to www.fnb.co.za from all the machines on the lan.
Can anyone give input as to why this is happening?
Jarrod
Problem sorted thanks to webafric support . Was old dns settings :)
Thanks to craig :)
