Supersonic Air Fibre Speed tests and service reviews
Dretastic06
I was also called … but then I declined because I’m on Rain’s 5g … now …
i have rain 5G but the strict nat type is off putting and also the latency spikes. wont mind the stableness of air fibre
  • Love
Reactions: Yuu
Kiemo
Did they call you ? Honestly where I am the tower is 0.6km away so I don’t have much problem I don’t game so that’s a plus
Gtx Gaming
Gtx Gaming
Yeah no call here, in cpt.
Throught supersonic lte now runs on mtn bussiness apn, so might not even need it. They also allow for open NAT on lte.
  • Love
Reactions: Yuu
CapoPlays
Theres no such thing as air fibre it's the same **** they provide in Australia NBN Wireless basically fibre to a base tower either fno own tower or shared tower from MVO and attennas on your roof straight line of sight with the tower, if you got trees, **** weather good luck to your connection
AadilG
Update :
Installation supposed to be done yesterday , techs came out but couldnt find signal. Was told to connect to a tour thatss 4km from home.
Came back today to re instal , Found signal at a tower thats 1.5km away.
Basically - there is a Tarana Anttena connected on my roof facing the tower. there is cable from there going into a poe adaptor that powers it on.
i am currently not yet live. i think there was an error in the username and password (PPPoe). I will have to update that when i get home from work. According to them , i should be live.
Attached is the Zyxel Routher that comes with the installation
Kiemo
Update :
Seems there is more problems with this fibre than anything else … suppose to be air …
Nurple Derple
Update :
Do they charge an installation fee?
Are there any penalties if you cancel?
Joseph matane
Update :
Good to hear don't forget few speed test update ❤️
AadilG
Update
when i got home (just after 6pm) its was live but around 10 25pm gone red again. Tech is coming out again today to check.
some speed test. I Have applied for the 100mb one
  • Like
Reactions: Yuu
Joseph matane
Update
Based on this speed tests ping is good DL is not excellent but not bad UL is good
Yuu
Just some feedback
Line has been stable , no drops in connection. Speeds are good too
You are getting faster speeds? Wasn't it supposed to be rate limited to 100Mbps? If not, this is fantastic.
Thanks for the feedback, really appreciate that. :cool: :love: :notworthy: :thumbsup:
ultimatebas
Have they started rolling out air fibre to other parts of the country like Durban and Capetown areas
  • Like
Reactions: Yuu
