I was on the
Supersonic Unlimited Air Fibre for R999.01 per month.
When I first got it in February 2022 I was disappointed because I didn’t achieve the speeds all the hype promised or the advertised hardware. Directly off install and setup I was only getting around 5/10 Mbps on my download tests using the supplied
TP-Link Archer MR600 v2 router.
Which still today more than 2 years after its release in South Africa is using the default released beta firmware and has never had a firmware update release where as Europe and the USA are already in their v21 and higher of the firmware upgrade release. Showing how little support there is for this LTE router in Southern Africa.
The promised
Tarana Wireless G1 Antenna they advertised that comes with the AirFibre package, which I specifically needed form my setup being on a small holding and one of the key reasons I chose to go with the Supersonic AirFiibre with
no direct line of sight to the towers or phone line/fibre options due to rampant line theft in the area.
Back then they kept saying antenna stock would be coming but never has. I was left hanging with a very slow and unstable connection. Then I found articles on the Poynting XPOL antenna here in Mybroadband so I bought the
XPOL-2-5G antenna at R8700 including all fittings and pole from Poynting for my setup.
As soon as I connected the antenna my connection went to 110Mbps download speeds in my tests.
For around 4 months my internet rocked, then I noticed it slowing down. I was lucky to get 25 to 30 Mbps during the day and 50/60 after 10pm/11pm at night. And since around July this year if I go over 25 gigs in data use it drops my connection to 5/8 Mbps. Cant do much when that happens, loading simple web pages is even a challenge. Usually by the next day it speeds back up to the usual 20/30 Mbps range until I go near the 25 gig mark again.
And in-case you might be thinking this is due to Load-shedding, its not. I have Solar and inverter with big battery bank and the tower I point to is at the Lanseria airport which has extra power supply and security being at the airport. So I generally don’t feel Load-shedding unless they kill my power for more than 12 hours and its very cloudy. Which has happened more than you would think. Thanks Eskom and the ANC, you are awesome!
Its also not my signal that has dropped because my signal strength is constantly at 100% and on very dark stormy conditions it drops to 75% due to the awesome XPOL antenna.
I have submitted loads of support tickets complaining about it, when they do answer the ticket I get the same stupid questions they give everyone in a ISP call centre, have you checked your plug, and stupid noob questions every time. Other times my ticket gets ignored and I just get a ticket closed notification.
And after a very frustrating back and forth each time, they pass the ticket onto their technical department which then answer me very quickly telling me to test the connection and bang its running at 100 Mbps again, this always lasts for around 24 hours then goes back to 20/30 and the usual 25 gig limit and the frustrating cycle repeats its self again.
So to sum it all up!
A top of the range 100Mbps AirFibre service that’s uncapped, unshaped and unthrottled for R999.01 per month are a blatant lie and is false advertising. Your account gets changed to an FLTE account because there are no antennas, It is shaped and throttled and does not give you 100 Mbps connectivity. You do not get the advertised G1 antenna, so you have to buy your own substitute and that cost me close to nine grand which I wouldn’t have minded so much if they actually gave me the advertised100Mbps connection I am paying for. Where I am located I doubt there is much network congestion so why I am shaped and throttled confuses me.
Supersonic was truly the best for maybe a year and a half, but since Calvin Collett stepped down from CEO the company and its service has become the normal rubbish service we get from all the providers, and that’s South Africa for you. Loads of crap options with not a single good one.
Now that Southern Africa has the new Google's Equiano and the Meta-backed 2Africa sub sea internet pipes and the recent pipe snap issues in the Cape sorted out, maybe South Africa’s internet will improve over 2024. Dont hold your breath!
