sand_man
- Jun 4, 2005
It doesn't sound as vibrant when you try to tweak the equaliser settings manually.
Agreed, tried that without success.
In the Bass Setting (under Speaker Setup), I have Subwoofer Mode set to LFE+Main, with a LPF value of 80Hz. What this means is that any frequency below 80Hz will be sent to the sub, even in normal stereo sound. My front stereo speakers can handle low frequencies though, that's why I have it set to this. Since you have smaller speakers that may distort at low frequencies, you may want to increase it to anything between 100Hz to 150Hz, depending on what sounds best for you.
Thanks. Trying that now.
Must say, I'm experiencing a little post purchase dissonance at the mo.
As much as I like the smaller speaker profile of the Sony's and now the Jamo's, it seems when it comes to low end speakers bigger is better. These Jamo's are sounding very tinny. They look bloody awesome though.
I suppose I also need to give them a chance to break in.
