Hey
I swapped out my ADSL router. I now have a Netgear 834Gv3 (against my will). I can dial an adsl connection from the netgear and connect to the net just fine. I don't want to do that though as I have a mikrotik to do all my routing etc. I have a PPPoE client connection set up in the mikrotik that I used with the old router, but that doesn't want to work on the netgear for some reason. I've enabled PPPoE relay on the netgear, but the furtherest in the dial up process I can get from the Mikrotik is "Link Established"... it doesn't get to "Connected".
I'm using an uncapped account, so that won't allow multiple sessions. To make sure that the netgear isn't dialed up at the same time, I used the disconnect button in the menu for the netgear and for good measure changed my username in the settings. When I check the connection status it does say "Disconnect", so I know that can't be the issue.
Ideas?
Ideas?
