Tamboerskloof, Cape Town ADSL problems
1979
My line speeds are incredibly slow and regularly gets disconnected (at least every half an hour). My download speeds sometimes drop below 1mbps. Telkom has indicated that, because I'm far from an exchange I can expect problems unless I drop my line speed. I've gone as low as 7mb but still experience problems.
021 424 xxxx
10Mbps line
WebAfrica capped
The line is obviously slower during general peak usage hours, but even at night I rarely get > 3Mbps these days. During the day I often can't even listen to a song on Soundcloud without it pausing to buffer.
traceroute to telkom.co.za (196.43.22.222), 64 hops max, 52 byte packets
1 192.168.1.1 (192.168.1.1) 9.112 ms 2.720 ms 2.856 ms
2 196-210-150-1.dynamic.isadsl.co.za (196.210.150.1) 8.182 ms 8.174 ms 8.224 ms
3 cdsl2-ctn-vl2276.ip.isnet.net (196.38.72.125) 10.254 ms 10.156 ms 9.189 ms
4 196.35.115.136 (196.35.115.136) 13.373 ms 16.530 ms 14.300 ms
5 168.209.6.12 (168.209.6.12) 14.433 ms 13.653 ms 13.708 ms
6 168.209.6.130 (168.209.6.130) 13.867 ms
168.209.2.130 (168.209.2.130) 14.056 ms
168.209.6.130 (168.209.6.130) 13.057 ms
7 196.25.247.25 (196.25.247.25) 12.596 ms 13.216 ms 13.320 ms
8 196.43.25.205 (196.43.25.205) 10.227 ms 10.882 ms 10.035 ms
9 196.43.39.162 (196.43.39.162) 31.824 ms 32.610 ms 32.750 ms
10 rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za (196.43.23.6) 35.506 ms 36.268 ms 37.066 ms
11 nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za (196.43.23.34) 33.835 ms 34.393 ms 34.791 ms
12 nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za (196.43.22.222) 36.934 ms 48.580 ms 37.073 ms
Upstream line rate (kbit/s) 640
Downstream line rate (kbit/s) 7008
Upstream line attenuation (dB) 6.5
Downstream line attenuation (dB) 17
Orvor
1979 I am experiencing exactly the same problems as you and I am on a 2mb circuit.
Our line suffers disconnections on a daily basis, slow throughput speeds and generally behaves erratically. I'm faced with calling Telkom at least once a week to request a report which works for a day or so then quality degrades again.
My ISP is Telkom. When I was in Jhb with MWEB my line quality was far better - no complaints. I can't provide all the details re ping speeds etc as responding from work.
1979
Glad to hear it's not just me Orvor! Please let me know if you manage to sort anything out with Telkom...
