Telkom and Packet Loss - How to explain it to Telkom
Scooby_Doo
Hey All,
I have around 2% packet loss on my line, which only really affects VOIP and gaming not throughput. I am struggling to get Telkom to understand that 2% packet loss is not normal, but according to them if I am synced and downloading at a certain speed then there is no issues on the line.
In terms of what I have tried, tested every cable (ethernet, phone line from router to wall socket), tested 2 ADSL routers, update routers firmware, 3 different ISP capped data accounts, checked for noise on the landline (which is not normally plugged in as I only have 1 wall socket) and tested via the ping utility on the router to make sure it is not my NIC on the PC.
Telkom techs have fiddled with my wall socket in my flat and have moved my line to a different exchange/port. However I still have the packet loss.
Now the question, how do you explain the issue to them? They are so dismissive. :(
At this point I can only assume there is something wrong with the copper between my router and the exchange.
ronnie_94
Is Telkom your ISP as well?
Hey All,
Geoff.D
Do you have the line filter plugged in regardless or do you remove the line filter in the belief it is not needed if there is no telephone connected?
Suggest you plug it in anyway and then see.
Scooby_Doo
I can't win, Telkom just sent me another SMS stating that the service is up and running again and that I must respond with yes it is resolved or no it is still faulty within 24 hours. This is the 3rd time they have done this.
For reference I have tested.
3 different ISP capped accounts
2 different ADSL routers
2 different phone cables from the router to the wall socket
2 different ethernet cables from my PC to the router
tested using the ping diagnostic tool on the router which rules out the NIC on my PC.
I do not have a phone, only the router plugged in. I do not use the phone and only have 1 phone port. ie I do not need a pots filter.
Afrihost
Tracing route to www.mybroadband.co.za [104.20.9.169]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms ZyXEL.Home [192.168.1.1]
2 * * * Request timed out.
3 22 ms 19 ms 18 ms cpt - up1.ip.adsl.co.za [169.1.5.105]
4 19 ms 20 ms 19 ms cpt - up2.ip.adsl.co.za [169.1.5.106]
5 20 ms 20 ms 19 ms cpt - net1.ip.adsl.co.za [169.1.5.128]
6 19 ms 19 ms 19 ms 196 - 10 - 140 - 198.ixp.capetown [196.10.140.198]
7 18 ms 18 ms 19 ms 104.20.9.169
Trace complete.
Ping statistics for 169.1.5.105:
Packets: Sent %3D 1000, Received %3D 917, Lost %3D 83 (8% loss),
Approximate round trip times in milli - seconds:
Minimum %3D 17ms, Maximum %3D 1290ms, Average %3D 80ms
WebAfrica
3 74 ms 102 ms 19 ms cdsl1 - ctn - vl2376 - ipc.ip.isnet.net [196.38.72.206]
4 31 ms 18 ms 19 ms cdsl1 - ctn - vl2376.ip.isnet.net [196.38.72.205]
5 * 63 ms 63 ms 196.35.115.128
6 19 ms 19 ms 19 ms mi - za - cpt - p7 - te0 - 0 - 0 - 0.ip.isnet.net [168.209.6.12]
7 20 ms 20 ms 20 ms 168.209.6.130
8 19 ms 19 ms 18 ms 196 - 10 - 140 - 198.ixp.capetown [196.10.140.198]
9 19 ms 20 ms 19 ms 104.20.9.169
Trace complete.
Ping statistics for 196.38.72.206:
Packets: Sent %3D 1000, Received %3D 974, Lost %3D 26 (2% loss),
Minimum %3D 18ms, Maximum %3D 1288ms, Average %3D 64ms
Vox
3 * 82 ms 87 ms telkom - upload - vlan - barrack - ipc.vox.co.za [41.193.121.9]
4 * 79 ms 82 ms vox - upload - teraco - cpt - barrack - ipc.vox.co.za [41.193.121.10]
5 89 ms * * vox - b2b - pts - barrack - ipc - int.vox.co.za [209.203.1.41]
6 85 ms 93 ms 82 ms 196 - 10 - 140 - 198.ixp.capetown [196.10.140.198]
7 72 ms 86 ms 81 ms 104.20.9.169
Trace complete.
Ping statistics for 41.193.121.9:
Packets: Sent %3D 1000, Received %3D 963, Lost %3D 37 (3% loss),
Minimum %3D 17ms, Maximum %3D 243ms, Average %3D 66ms
Scooby_Doo
Well I am still fighting Telkom, and today... The techie put a adsl splitter between my ADSL router and the wall socket to fix noise on the line.
How? How do they possibly think that would work knowing and seeing I only have my ADSL router connected I do not have a phone connected anywhere...
Scooby_Doo
To close this off, issue was never solved, but I now have a 10meg line for the price of a 4meg to compensate for the packet loss.
