Telkom: Ethernet vs USB
evilsee
Hi I am sure I have seen the answer to this question before on the forum, but I cant find it.
Do both (ethernet and USB)the telkom ADSL pots have a firewall function, or does just the one product have it or perhaps neither?
What I want is to be able to block all incomming request and only allow request through that originate from inside my local LAN.
I would appreciate any help, or perhaps a link to read up about the telkom products, If I have to I can purchase one an alternative ADSL router, oh I have the telkom adsl ethernet POTS.
thanks
e [}:)]
evilsee
ok,
so then what adsl modem/router should I get, I want one that has a built in firewall or atleast one that can block all incomming requests.
e
zipper
I have been using a D-LINK 504G router for 2 months or so and it work very well. The local D-LINK suport is very good. I run the Firewall, IP Filter and NAT and it work a charm. The retail price should be about R1200. I have also seen some good comments about Netgear routers, but i don't have any expierence with it.
alex
I used to have a netgear router , for some reason had allot of problems with it , i am currently useing the D-link G500 and it works like a charm no problem even with my *** line . netgear used to dissconect
