[Telkom] - Possible to temporarily upgrade line speed?
OtakuD
Hey peeps, I have a number of large files to pull down thanks to Black Friday, was wondering if it was possible to temporarily upgrade my line and then revert it back after a few days? Any fees/penalties that will be incurred for doing so? Thanks
CataclysmZA
It depends on what speed you want to move to. If you're not on a 10Mbps port and you're moving from 4Mbps, for example, a tech will have to physically move you to an open port in most cases.
If you don't want to deal with that the other alternative is Rain's off-peak uncapped offering, but you need the right hardware to connect to the network.
joker08
If ur services with telkom is working, leave it as is.
It's not easy to deal with Telkom these days.
