Telkom Speed Test ?????
Masu
Below is the data used to calculate your download speed:
Download time: 0.031 seconds
Size of file: 500 KiloBytes
Estimated line speed: 131612.9 (kilobits/second)
Estimated line speed: 16129 (kiloBytes/second)
I have a 385 line and am definitely not getting more than normal speeds, in fact web page loading is slower than usual and when I did a speed test this is the info I got.
Wish it was correct though.
Anyone else having the same problem?
PostmanPot
what were the results the first time you clicked test?
you are getting those results cause you already did the test.. so the results have been cached, so the http test loads automatically.
Masu
This test was the first test. When I redo the test, I open up a completely new web page and run the test. If I redo the test without doing this, this would be the result.
Results:
Estimated line speed: 255000 (kilobits/second)
Estimated line speed: 31250 (kiloBytes/second)
Now during a re-test I get.
Results:
Download time: 79.281 seconds
Estimated line speed: 51.5 (kilobits/second)
Estimated line speed: 6.3 (kiloBytes/second)
I am in Sea Point CT and my webpage loading is still very slow. Anyone else experiencing slow speeds?
http://www.telkom.co.za/attheoffice/products/dsl/speed1.html
