SauRoNZA
Why sell the wrong one in SA then? I'm assuming only the non-mppt is available here or are there both?
The article was addressing load shedding. Not Solar.
So there’s nothing “wrong” about it.
It Takes a lot more than just an inverter and battery to get a back up / solar solution going. ... and needs plenty of wall space. Not really a great comparison of two lots of premium equipment.
What he means is you already have a large inverter in the Powerwall to do DC > AC for the house.
You only need a small inverter and MPPT to add Solar to the Tesla and not a monster that runs the whole house so it can be quite barebones.
Actually not sure you need an inverter at all? It’s surely just going to be DC > DC.
Now you understand why I asked what I asked...
Nah, the powerwall doesn't take DC input.What he means is you already have a large inverter in the Powerwall to do DC > AC for the house.
Now you understand why I said what I saidNow you understand why I asked what I asked...
Combining Systems with Powerwall | Tesla Support South Africa
Adding energy storage to your solar system is the best way to maximize your system’s value – allowing you to use solar power day and night. Powerwall can be integrated with a new or existing solar system.www.tesla.com
I question that 100% DOD.The main benefit with the Tesla is the 100% DOD and retained warranty, if only the capacity was more.
Agree, they could really improve it dramatically. They are going with the 'plug and play' and asthetics approach. High end market. You could just build a cabinet for your solar stuff tho.Yeah I saw that now.
It’s really a bit silly.
Presumably the Powerwall+ does since the MPPT is onboard.
And still made in china*Dutch
It is an AC coupled device so maybe that does mean it can only take AC as an input.
I know they pretty much always pair the Teslas with SolarEdge for some reason so maybe it relates there somewhere.
In the US you simply get this.
Tesla Solar Inverter | Tesla
Tesla's expertise in power electronics has been combined with robust safety features and a simple installation process to produce an outstanding solar inverter. Learn more about going solar with Tesla.www.tesla.com
But I’ve never seen it here.
As a complete Tesla package for that market it makes sense because not everyone wants to go solar and in that regard it’s like the Victron super modular approach.
And it does output AC it seems which is a bit silly but for the above reasons makes sense from a modular perspective.
At the same time one would think you can simply jack straight into the battery and skip all the double conversion.
I’d they made a 20 kWh I would have considered it more seriously.
What he failed to mention is Tesla warranty, you get longer warranty if you only use to 50%<DODI question that 100% DOD.
Is it not just underspecced? So what we're calling 100% of 17kWh is 80% of 20kWh (sorry, I haven't done the math - purely for demonstration).
It's needs another standalone grid tied inverter to charge it as it takes power from mains, it's a gridtied solution when power fails it backs feed from the only one cable installed to power your house.Strange, so the Tesla Solar Inverter is both an DC to AC inverter and a DC to DC converter, I wonder why they went at it this wayIf that is true then it sounds like you won't get away with just an MPPT to add solar on as you say, it is an AC coupled device.
Which says to me that their claim that you can go 100% DOD without affecting the life of the battery significantly is marketing bunk.What he failed to mention is Tesla warranty, you get longer warranty if you only use to 50%<DOD
Warranty goes shorter the more you run it down,
Grid tied inverter...and the Tesla does allow solar via a basic inverter.
What he failed to mention is Tesla warranty, you get longer warranty if you only use to 50%Warranty goes shorter the more you run it down,
Nevermind powerwall 2 still needs another device that's 50k to tell it when and what to do
Nah, not from what I can see. It takes AC to charge, so any inverter should work just fine.Grid tied inverter
"Since Powerwall is an AC coupled solution, it is compatible with all inverter types."![]()
Now you understand why I said what I said![]()
