Swa
- May 4, 2012
I claimed that the standard wiring can be used for 12VDC. Your straw men and red herrings aside that is still correct. I said multiple times it's for low power applications so they don't prove it inviable. The OP even mentions low cost housing so a tv and a few lights perhaps a cellphone charger is it. You still don't seem to understand the 360W example. It's the limit of what I would consider viable and not necessarily practical but you seem to be treating it as a starting point. It's interesting that the examples can use anything from 9-18V.Stop talking BS> You claimed that a home can be converted to 12VDC by using the existing electrical wiring in situ as the wire can handle double the current using DC as opposed to using 220V AC. You punted it was due to the skin effect on copper using the 220V AC. I have shown and proven to you it's absolute horseschit as for a 360Watt appliance you need a 7.5mm diam wire for the load you claimed. With 220V AC the calculated load is closer to 3KW. I also showed you that at 50 HZ there is no skin effect to be concerned of with 2.5 mm2 standard home wiring.
As usual you make claims and as you get caught out you alter your story by thumbsucking more BS and then talk in circular arguments to try and convince others that you had a different meaning. Now you claim that the idea was to cut out all high power devices, like computers, Hifi's, Surround sound systems, hair dryers, etc..
So lets go camping at home and lets cut out all conveniences. At the same time only plug in one device with wattage far less than 360Watt at any one time. The rest of the family must queue in line to use their conveniencies or appliances.
That makes someone doing it a blatant liar in my books! Thats a trait all conman and politicians use very well. Spin Doctor extraordinaire.
By the way I have used your own example of 360Watt to prove to you your whole argument and claim is a total fallacy.
As for your high power examples, it was mentioned long ago already that higher voltage DC is a solution so you haven't presented any facts against it.
I asked a simple question. I am not arguing against their safety but quite the opposite. They are VERY safe considering the large amount in use. Their performance specifications are quite good compared to lead-acid and VRLA but I won't delude myself into believing they are near perfect. The "pill-box" batteries I mentioned are even safer, more long lasting and has better deep cycling. I am not punting any total solution as there are none but these are certainly an interesting area to keep an eye on. One step closer to home made and serviced solutions. For now I am just watching all the tech fighting it out.Strange that over many threads you kept on asking why those batteries are not available locally sort of punting them as total solution . Now you yourself argue against their claimed performance specifications and questions how safe they are and punting another battery which are manufactured using pill box equipment as total solution even after I showed you they claim it could not handle deep cycling at all. Oh, yeah they shipped 100 units according to the info you supplied)
BTW I found a local supplier with LiFePO4 batteries in stock. A total solution.![]()
Still with the massive sense of ego I see thinking that you are everyone.PS: Not even your God can understand you or your motives, no wonder everyone hates your posts in PD, Christians alike.
Let me enlighten you a bit. Most power supplies are still linear so they are bulky and waste a lot of energy. Even most PC SMPS are nearer to 80% efficiency. The green ones are in the region of 90% efficiency. You're going to have to pay through your nose for 95% efficiency and I doubt you'll readily even get 97%. It's not worth it for solar power and most probably not even for grid power.Quiet a few misconceptions in there again. Sure the efficiency of the older type AC to DC power supplies was low due to the bulky size of the components to handle the heat to account for the voltage drop from 220VAC to DC. In general transformers were used with linear electronics. In modern day times that is not the case and efficiencies of high in the nineties can be achieved (as high as 97%+) by using high frequency Switch Mode Power Supplies. SMPS. (Google some and learn) There are no way you can get the same efficiencies going 12VDC-AC or DC-DC as you would get using AC-DC with SMPS. (To know why google some more) If you really know how a computer PC Supply works you will understand.![]()
If you know the real world figures you'll know DC-AC-DC is optimistically 80% efficient making it a good yardstick for pure DC.
Again your red herring of high power low voltage DC (not what was claimed) is deflecting from the reality that DC-AC-DC is 80% efficient being optimistic. DC-DC conversion is at least as efficient as AC-DC using SMPS.Here again you are trying to deflect from reality. Converting from 220VAC to DC direct have very small losses by just rectifying 220VAC to 400V DC as a DC bus, this immediately gives you the required level of DC for most consumer appliances. Then using SMPS to convert that 400VDC to any other xDC voltage can be achieved easily with small components that can be very efficiently done with SMPS designs which size is fairly easily scaled depending on the load required. Therefore the reason rather use 220VAC as home reticulation on standard 2.5MM2 wire and convert the 220VAC to 5VDC with an SMPS which a simple and effective solution directly at the point where the load is required; like charging your cell phone in your bedroom. Thus 220VAC low amps in 5VDC higher amps out at 97% efficiency. If you want to do that using direct 12V DC you will not get the same efficiency as the DC-DC conversion will be less efficient and the phone charger larger depending how you do it all depending on the electronics design and whether its digital or linear electronics in the design. If you go direct to 12VDC you will have to use thicker wire as I have shown you numerous times based on the load required. A simple 360Watt appliance or device will require a 7MM dia or 33MM2 wire to operate. Thats for one device. Totally impractical and illogical for a home dwelling.
Again you detract from your original claims that an existing home can be converted to 12VDC without major rewiring and without any current or wattage limitations in fact you claimed you can double up the amperage in the standard 2.5mm2 home wire circuits using 12VDC instead of the 220VAC which was proven and shown to you as absolute garbage.
You like making accusations without substantiating them? That seems to be a standard for you. I showed you sound physics proving that 600V vs 240V (not 12V) only yields a saving of R45 in solar panel. So you are falling for marketing hype and using the argument from authority to try and justify more expensive equipment and cable. I have that bridge ready for you.Another lie, this is becoming so standard for you even in the PD sections. I was shown to you that the choice Isheed_cn made to use a 600V high power solar panels instead of 12VDC was based on sound engineering principles by expert companies as a standard. One of their main reasons was to save on installation costs as it is clear and proven to you that sending high voltage DC at high loads to supply a complete dwelling with the required power(watts) requires thinner and cheaper copper cables than supplying the same power (watts) for that same distance at 12VDC.
You are coming up with fallacies and changing the goalposts. I never claimed that high power devices should become low power devices. I repeatedly said more support for low power devices. We are seeing that support right now.Your fallacy argument to solve the problem was that everyone should wait until new appliances are designed that will cut out these high power appliances we use and wait for the world to design low power appliances that works directly of 12VDC and legislation must be changed. You randomly googled for such appliances like your 12V DC PC supplies and i showed you they are expensive to buy, expensive to add the required 12VDC 33MM2 or 7mm diameter wiring required which would require civil mods to route the cable and that the current standard 2.5mm2 home wiring can not accommodate the load amps required at 12VDC. Then you thumsucked another few arguments to counter that saying low power devices and thus advising laptops as the solution.
You keep on changing the goalposts.
