Most equipment actually functions off 12V. It is therefor the ideal voltage to use. Phones charge on 12V chargers. Laptops charge on 12 chargers. Camping gear is made for 12V. Our latest TV has a 12V wall transformer. The highest voltage in a computer is 12V. The list goes on and if 12V is the standard in use then most manufacturers will design around that instead of using some arb non-standard voltage.
No, it doesn't.
Phones generally use 5v DC @ 2A or 500ma, depending on negotiation with the USB socket.
They convert this internally to 3.3v for SoC, and ancillary circuits. Charging circuits will use different voltages depending on how many batteries in the device. Lithium is usually 3.2v, but designers can run stuff in higher voltage (batteries in series), or higher ampage (batteries in parallel) depending on their specific design.
The highest voltage in a computer is indeed 12v, but there are a number of 12v, 5v lines.
Modern CPU's can use 100w on their own, and higher end graphics cards are often in the 300w range.
Add in other bits, hard drives / ssd's etc, and you can easily hit 500w.
500w @ 12v = 41amps. PC power supplies have multiple rails, and supply multiple 12v over parallel cables.
Are you going to run twice the cable to supply one single computer. I have explained this a couple of times relatively clearly.
If you don't understand basic concepts, suggest do some further reading of why I keep pointing it out repeatedly.
That's bollocks. There's no single strand requirement and any voltage drop would be mainly due to the power source.
Suggest read up on skin effect (which affects A/C cabling, and cabling requirements for high voltage DC, before claiming "bollock's".
Well there is your problem. Nobody else is advocating 600V when 12-24V would suffice for most applications.
It quite obviously won't be sufficient for most applications as has been pointed out repeatedly at length by myself and others, and the solution for that is running at higher DC voltages. DC works for low current draw, at short lengths. If you have higher current draws, the voltage loss is high at standard cable lengths. Assume you have 20m from your DB. Calculate the voltage drop over the size cable you'd need to run a 500w computer. Or a kettle. Or a vacuum cleaner. Or a tv. Or anything really that uses a few hundred watts of power.
Low voltage DC will work for specific situations, but only a narrow subset of daily used items.
If all your house uses is a cellphone, and some low voltage 12v lighting, then great, DC will be a solution (for short cable runs).
For anyone else, not really.
Higher voltage DC would work - eg 240v DC would work, but then again, the cable sizes aren't a benefit, and you still need DC - DC voltage regulators to step down DC voltages to what the device needs.
