Tightening Wheel Bolts With Torque Wrench. Which fitment centre does it?
adamr
As the title asks, which wheel fitment centre can tighten my wheels bolts with a torque wrench? ... the setting needs to be 130nm
BCO
Why not just buy a torque wrench and do it yourself?
adamr
question is it it necessary to tighten the wheels to torque settings? ... (see Porsche mentioning this in the manual) ...
tomorrow morning i will phone HiQ
F
Fudzy
Guest
The question I'd rather be asking is whether or not your service dealer could void your service plan / warranty by finding out you haven't.
adamr
LOL imagine if they did ... rear tyres were changed but they did not use a torque wrench ... only saw that in the manual after ...
HapticSimian
It's a safety concern more than anything else. Too tight & you risk weakening the metal of the wheel studs which could lead to them shearing off. Not tight enough & they can work themselves loose over time.
It's one of the reasons that BMW is pushing run-flat tyres...
F
Fudzy
Guest
Huh? How do run-flats attach to the hub?
HapticSimian
How they attach isn't the issue... they bolt on like any other wheel. The thinking is (at least in 1st world countries) that people with run-flats won't ever have wheels changed/replaced anywhere except at a dealer/tyre fitment center. By implication the bolts will more often than not be correctly torqued by someone 'qualified' to do so.
Thus, no incorrectly self-fitted spare tyres to worry about...
placebo
Tiger Wheel use a torque wrench as well.I use Fourways Crossing Branch.Excellent service but always very busy.
F
Fudzy
Guest
Yeah but failure from over/under tightening would have nothing to do with whether or not you have run-flats or conventional tires.
HapticSimian
No, but run-flats are fitted when the car is assembled and thus correctly torqued. If and when something happens to a tyre, first port of call would be a qualified dealer/fitment center and NOT your Aunt Mildred fitting her spare on the shoulder of the N12
CaTcH21
And how will they ever prove that you didnt ?
Ecco
Are you saying normal tyres are not correctly torqued when the car is assembled?
After you fit your normal spare, a lot of peoples first first port of call is a dealer or fitment centre.
And who says just because you getting another run flat, your dealer/fitment centre is qualified and will use a torque wrench to attach the wheel? Guys take short cuts everywhere.
You make no sense dude.
xrapidx
got a thread on this somewhere, decent ones are R3000+
Probably not - my S2000 service manual has a torque number for just about everything that screws in...
HapticSimian
Are you saying normal tyres are not correctly torqued when the car is assembled? How on Earth did you manage to infer this?
After you fit your normal spare, a lot of peoples first first port of call is a dealer or fitment centre. Really? So nobody fits their spare and then forgets about the flat tyre in the boot? Or if they don't forget, they leave the former spare fitted to the car & just replace the tyre on the other rim?
And who says just because you getting another run flat, your dealer/fitment centre is qualified and will use a torque wrench to attach the wheel? Guys take short cuts everywhere. I'm not saying they are, I'm saying they're meant to be.
You make no sense dude. It's quite clear in my view.
Regardless of all this, the run-flat story is an aside to why it's important to have the nuts correctly torqued in the first place.
adamr
went to HiQ ... they could not jack the car up on their machine ... the arms could not fit under the car, because of it being so low :)
... eventually they manually jacked up each front end and they had an on car wheel balancing tool (glad i found that one, best balancing ever, no need to take the wheel out :)) so they balanced the wheels for high speed and the owner organised a friend from his engineering firm to tighten my bolts to 130nm (Pros of driving an exotic :)) ... the car after balancing is so much more responsive in terms of steering feel and also psychologically its driving better than ever before :D (no shudder thank god at 120km/h)
xrapidx
Car shuddered :eek: Hate to know what it'd do at 300 :p If it can, you have to... at least once...
Fazda
ALL TSW Branches torque your wheels for you :D
Adam, time to stop wasting petrol and just go straight to TSW for all your needs!! ;)
