Rudolph Smuts
- Apr 20, 2023
Hi guys.
I am seeking some advice.
Our firm recently switched over to using VOIP phones.
It is a Grandstream GXP1165 VOIP Phone. We have 2.
We have 1 VOIP account through Afrihost which they said supported 6 devices. We have one 087 ... number.
The problem is that I am not able to transfer a call from the 1 phone to the other.
One device is plugged directly into a Wi-Fi router via ethernet, the other is plugged into a Wi-Fi Extender.
I am aware that these devices to Direct IP Calls but when I enter the other phones address the call fails.
Both devices IP addresses are more or less the same. Ex. 192.168.1.___. Even the one on the Wi-Fi extender is in the same format. 192.168.1.___.
When both phones are plugged into the router the Direct IP call feature works
Another idea i had was to try and transferring a call to our number again, but this only opened the phones voicemail.
Does anybody have a solution or a recommendation? Any help would be much appreciated!
Another problem with the phones is that only 1 rings and shows a call when called. The other 1 is able to call out but doesn't show calls received. Any solutions?
