Ubiquity equipment: No connection with remote site
gerasmus
Good day people,
I have Ubiquity AirOS equipment installed in wireless bridge mode at my home by a local WISP who's now gone on holiday.
My link broke down on 21/12/2011
I am unable to ping my remote router or the UB2. I guess UB2 is at the ADSL side.
My router IP is 192.168.1.1 and is DHCP. I do not want UB's to be DHCP provider.
Ubiquity1 IP: 192.168.1.10 (UB1) set to static IP.
Ubiquity2 IP: 192.168.1.20 (UB2) set to static IP.
Subnet 255.255.255.0 for clients and UB's.
I reserved IP's on the router for my remote PCs/laptops as well us for the Ubiquity equipment.
I have direct line of sight, a distance of about 7km. After initial install the WISP told me that the signal is extremely good. I can only connect to UB1 (192.168.1.10) by changing giving my PC a static IP but not to UB2 (192.168.1.20).
When I previously had the same problem just over 4 days ago the Wisp told me he rebooted the equipment. However, I've only been able to reboot UB1 as I can't connect to UB2.
Would I have to drive to UB2's site (my router) and reboot from that side as well ?
Is it very easy (yes I know the term is relative) to setup my own link ? I am currently paying the WISP R400 p/month just to use their equipment. I've seen kits going for upwards of R2100.
Background info:
I use my own ADSL router and Telkom line and pay a WISP to relay my ADSL wirelessly. I only rent their equipment and nothing else.
I use my own ADSL router & ADSL line to relay my ADSL wirelessly to my house which is several km's outside ADSL coverage. Being Friday 23/12/2011 everyone has left for the next two weeks. This means no internet for me (frustrating), and my WISP doesn't answer their (cell)phones. They're probably thinking that their customers can go screw themselves, wait until 04/01/2012. I've been experiencing the exact same problem for the 3rd time, each time the wisp "fixed" it in my abscense.
Thank you people.
Anthro
#1 . Which one of the Ubuiqity models are you using ?
# 2. Which model router ?
I have a Bullet 2 in my garage which I could link up to take a look - will advise you when I get home tonight..
Used to run a similar setup over 20km (no line of sight :D) kickass little device that
My device was linked to WAN port of my Linksys WRT54GL, and connected to another station on same IP and subnet
warwickw
OK So UB1 is your side UB2 is the far side, sounds like UB2 or something on the far side is doing DHCP for you, and seeing the link is down between UB1 and UB2 you thereforce can't get an IP address or internet.
I suspect UB2 is powered off or died, you will need to take the long walk to there and check whats going on. If you have passwords for the UB's logon on to UB1 and see what it says.
|tera|
Master of Messengers
Yes. Drive the 7km and reboot the router at UB2. Which you could have done in the time it took you to post the thread ;)
