Unifi solution for home with concrete roof and no ceiling void
Muttley
Hi guys,
A friend has asked me to help him rid his home of the wifi extenders & powerline adapters in his home as they're not working well at all.
It's a single story home but it has a flat concrete roof with no ceiling void whatsoever. The concrete is a big challenge as there are so many deadspots and mounting access points in the centre of the various rooms will not look great as there would be an ethernet cable on the surface (even if it's painted).
I can run ethernet cable on the roof, down the walls and drill into the each room.
I was thinking of using the Unifi AP AC LR's but do you guys have any other suggestions for a Unifi solution?
(I think someone here once mentioned using something like their Powerbeam outside the house but not sure if this is correct or how I would go about this)
Thanks in advance
Edit: It's Friday so please excuse the spelling typo in the heading
$m@Rt@$$
We use one of those long range Unifi APs at the office. Big double story building with über high ceilings.
Those things are beast. We could probably supply connectivity to the whole business park.
SauRoNZA
How do they have light fittings?
Surely you could use the same to fit the Unifi setups.
Muttley
I've installed one in a home previously- the range was not that good but then again, I had to put it on a tv stand as they also had concrete roofs :erm:
$m@Rt@$$
Yeah, if I had to guess the idea of those domes are to mount it like a ceiling light for it to project back down and outward. That's how ours is installed and it really works great.
Muttley
I think I also made an error in that I setup the device with a preference of 5GHz over 2.4GHz so I don't think this helped either.
Slootvreter
NanoStation Loco M2 mounted outside, pointing at the house. Weird solution, but works well. The M5 will probably also work well.
OCP
Hi guys,
Thanks in advance
Concrete/dense walls and WiFi don't play well together :)
If surface cabling is an issue then these are some options:
- drilling through the slab from above
- chasing a channel in the concrete
- mount a length of wood across the ceiling (painted grey/white it looks quite nice and minimalistic) + chase a channel in the wood with a router to hide the cable in
- go shout at the architect/builder for being a dumbass for not including conduits in the walls/ceilings
Muttley
Hi all,
Many thanks for the suggestions.
I may need to post more questions here once I've conducted a proper site visit.
Geoff.D
One last item. Do not under any circumstances drill through the slab and compromise the waterproofing! That will be a real disaster.
Look for a neat way to disguise surface mounted cables that looks like a decorative feature and not just trunking.
Muttley
I was going to suggest the same.
Not keen on mesh setups... but thanks
I would never do that... I think I'd get shot!
Thanks for the suggestions
Geoff.D
I bought a house once with a concrete roof. The absolute worst decision I have ever made. It was a nightmare from start to finish. I never dreamt that one could have so many problems with a simple thing like a roof. Everything was an issue, from the electrics to the plumbing. It drove me mad for three years to get it into a state where I could with a good clear conscious get the house into a state where I could sell it. Never again.
Muttley
Fortunately its not my home :D but the wifi is my prob :wtf:
The_Librarian
Another MyBB
Super Moderator
My suggestion as well for the exact same problem a while ago.
Plus you get wifi coverage outside as well.
