USB cable missing in action..need tower info
Jhbgirl
My friend (who is not a forumite) has lost his usb cable and now wants to call sentech and moan abt the crap speeds (about time too) but he doesn't know which tower he connects to. From previous experiences with the helpdesk I know they will want this info along with urine samples etc. Is there any way to find out what tower he connects to while he is on the ethernet cable? I know he lives in Constantia Kloof but I'm sure there is more than one tower he can connect to from there.
: 256k : 110 Helderkruin JHB : 10% :
Dean_Henstock
To be honest no, as the ethenet cable uses ppoe and will not report this info back to him.
Keep Surfing
JAS
You can plug the Ethernet cable directly into a PC's lan port, then install the supplied software selecting the Ethernet interface option. Once loaded, the supplied dialler will supply all the normal information, such as tower number, signal strength, RSCP and ISCP values.
Kai
yep... what JAS said. if you plug it directly into the network card, then you run the normal dial-up software and it works egg-zachary the same as the USB setup.
<hr noshade size="1"><font size="1"><i><div align="right"><font color="red">one day we will all look back at this... laugh nervously... and change the subject...</font id="red">
tower82(mintek).randparkridge.jhb|sig:9%|node:3|snl:0%|ber:28%|256k</div id="right"></i></font id="size1">
kickass72za
Sorry but i have to say this..... why the F@CK should we be doing all the damn techie support as users to supply them with the info
Personally..... would phone them and say you dont give a **** about what tower etc you are connected too.... They can figure it out..... NOT YOUR PROBLEM.... The network traffic is slow and i want a F*cking ticket now!!!!
Would love telkom to phone me and ask me where the routing of the cable goes to after it leaves my premises!!!!
regardtv
Actually, if he uses the windows software that comes with the modem it WILL show him the tower information.
Only under linux with PPPoE does it not work ... (or if you don't use Sentech's dialler)
<hr noshade size="1"><font size="1"><div align="right">Am I surprised they missed their origional deadline for 256K ... <b>nope</b>.
Will they make the 128/512K deadline ... hope so for their sake
<s> 16 17 18 19 20 <font color="green">21 22</font id="green"> 23 24 25</s> <font color="red"><b>26</b></font id="red"> 27<font color="green"><b> 28 29</b></font id="green"><font color="red"><b> 30</b></font id="red">
</div id="right"></font id="size1">
Jhbgirl
K thx guys. Will give him the info.
