Using bank card out of country
Onizuka0701
I bank with ABSA and I'm going to Kazakhstan tomorrow night.
Is there any procedure to follow to stop my card from getting stopped while I'm there?
Lord Nikon6
For credit card you need to either use the app to enable the card for international use, or call their call centre. Debit card I am not so sure.
braniac
I'm with different bank but needed to activate my card for use outside of South Africa. Did it on the banks app though.
Daruk
If nothing in the app, then call the bank. Really simple.
rh1
ABSA? Dont worry, I'm with Standard Bank. Not sure why though. Just been to lazy.
Onizuka0701
Have had no problems with ABSA so no real reason to change.
Its my debit card, will try and find out from the bank today.
Daruk
Yoh, ABSA people have been robbed blind in the past. Seems to be quiet lately.
Onizuka0701
Seems I have to change my card from a 5 number pin to a 4 number for some reason.
They also have to note that its going to be used overseas or it will be stopped.
ShaunyCT
You can change it on the app and their online banking.
Some countries use 4 and 5 digits and some just use 4 digits.
Onizuka0701
Some countries use 4 and 5 digits and some just use 4 digits. You can change your pin online as well.
Thanks sat there at the teller activating the card on my app like a dumbass...
So all should be well now
